I was where you are, sometimes I’m still as confused as before I started.
Fronius or Solis, Victron or Sturder, FreedomWon or Pylontech. MPPT or not … you don’t know what you don’t know.
I have deduced, over the years, that some will focus on the highest efficiency system. The next person does not care about that, more interested in other core functionalities, some focus on expansion potential … and/or whatever else makes us tick as individuals.
You can also use a trusted installer having loads of experience, who installs you the best system they can … on what YOU told them you wanted, YOU thought you wanted, YOU could afford at the time.
You don’t know what you don’t know.
Like, having installed your preferred system with Xkw of panels, the weather comes past and says nope, you can get a couple of 100watts only … for days on end!
Or you missed that palm tree/chimney, leaves in the neighbor’s property, affecting your panel production sometime/s during the year.
Or the batteries are too small, lifestyle changes are needed, even more automation is needed … rabbit hole man, rabbit hole.
Or you need a bigger inverter = more batteries required + more panels = even more expenses, and don’t have the roofspace or what not.
With all that, all the carefully deliberated engineering specs are out the door man! Gone. The system is not exactly what you thought, too small, too big, not what you thought you wanted or needed.
So, over time, having done all I can to make mistakes, to mitigate those bummers having lived them all, done them all, my advice: Start smaller.
Why?
After you have bought your system, having used it for a min of 1 year (summer and winter), having adjusted the lifestyle of the house as best you can to fit the system, I promise you, you will change your mind, you will want to alter this or that or whatever you can.
Walking the talk versus Talking the walk with your own system, having deduced with actual facts and figures, what it is you really need/want, what works for YOU.
Start smaller and enjoy the journey. Buy, sell, upgrade. Have some fun.
