Ai ja jai. Sometimes it helps to speak to a person … start by reading what they say.
Facts:
Lady has a UPS, she chose Victron being a LF inverter based on what she researched.
She added a FreedomOne 100ah battery.
And a Cerbo.
Was supplied and installed by a reputable company.
Panels, cannot REALLY be justified at the moment, usage too low, not always at home, and there are is a regular “reappropriation without compensation” issue in the area.
The core reason for this purchase was that she can now work from home … “accidentally” she found that she can use her MPII 5kva to cook with, as her preferred devices run with ease on it, a joyous discovery for her, during LS.
So what’s all this deep analysis of losses and Pareto Principal about?
It is a UPS that with clever usage of existing software, can become a clever UPS.
Let’s focus on that, shall we?
ESS is enabled …Teamviewer is a cool tool.
She learned that no MK3 cable is needed.
And the file to reset everything back to non-ESS, is stored on her PC.
Showed her DVCC, to sort the charge amps she asked about.
Showed her Keep Charged if in doubt … same as the UPS before.
My suggestion: Run on Optimized without Batterlife, SOC set to 100%.
Then set two charge Schedules:
- One at Time X when it is cheap.
- And if there was LS during that slot, set a 2nd one at Time Y.
… use the cheap Eskom rates she us eyeing.
The other things I wonder about:
Keeping a Lithium batt mostly charged?
Why not use it especially IF the sums show that one can buy at a lower rate from Eskom at night?
So use the batt at a more expensive Eskom rate, and recharge it on a Schedule?
EDIT:
Now that we are back on track, let’s see how far we can push a UPS to get clever?
