Hmm, MPPT’s have a heatsink on the back and can heat up quite a bit so I would avoid mounting any of these products on wood type material (excl. crebo)
I would most probably recommend an aluminium plate as it can help with heat dissipation and can also look nice if its on some visible spot
I’ve seen people use that diamond-pattern sheeting on top. Makes it look good as well. Personally I’ve always just screwed it directly to the brick wall… until the last time, when I decided to put it in a network cabinet
Check out Nutec plain sheeting. (9 or 12mm)
I bit of a learning curve to drill etc. but an ideal solution. Flat sheets_Facades Apr 19 2012.pdf (2.3 MB)
Yes, but it’s not made from asbestos.
Drilling it is far easier than a brick wall but not easy to screw into (you get one chance!)
But it won’t go up in flames and this is a real possibility with a power panel.
Nutec is a fibre-cement product.
It is used for ceilings, cladding of buildings and now is a replacement for timber.(gates are now made with Nutec planks)
Nutec works best if you can screw through the board into wood at the back.
That is how it is normally installed and anything with weight should not be screwed only into the newtec board.
I’ve had screws rip through my facia board in the past, which is a similar material, so this makes complete sense. Whenever that happens, I usually end up drilling a much larger hole, and putting a screw and washer into the concrete below the roof beam the screw has just pulled out of…
I am a fan of rivnuts.
You don’t even have to use the tool. Simply drill a hole so the body fits and the lip at the end will stop it pulling out…https://www.rivets.co.za/rivnuts.php
Was coincidentally thinking of this myself the last few weeks and then out of nowhere a thread on the subject!
A lot of the youtube offgrid videos etc. have the stuff mounted on OSB which is super convenient but I noticed that it doesn’t seem to be common here, never see it in photos of installs here etc.
Not sure if the difference is because we have stricter fire codes, or because we have brick walls or something else.
Anyway the fact that its not common here had me pondering alternatives, I suppose those aluminium composite panels might work nicely (though 10x the price of OSB)
The panel builders mount everything on chassis plates. Often these are mounted in enclosures but they could also be mounted on a wall…
And they would be happy to make a custom sized unit on request.
