Thought I would share our solar setup. Purchased a fixer-upper at the beginning of the year and having a small solar install to start off was always part of the plans. Plan to stay here at least a decade or two and trying to be as green as possible is the plan.
Did plenty of research first and became a bit despondent at the pricing around the solar installation. Had 3 installers come out and assess the job and give a quote. I then joined the “other forum”, of which I would not mention the name haha, to find other real people that had the same requirements as me. To gauge what’s needed.
Anyways, fast forward to a couple of forums posts and calls later with Jaco, not forgetting a global pandemic, we finally decided on a system within my budget. How I ended up with Jaco is that there’s a clear difference in pricing based on location. That’s a topic for another thread though.
Kudos to Jaco and his team. These guys work ethic are impeccable. We have been dealing with many tradesman since moving in and have had countless issues. If only Jaco did construction work as well haha Added a couple of pictures and details below.
Victron MultiPlus-II 48/3000 + Venus GX + SmartSolar MPPT 250/60-Tr
Pylon 5.9kWh US3000
8x410W Canadian Solar panels
I’m not sure of my setup direction, but it is 4 on one side and 4 on the other(newbie here):
Yes, Jaco clearly is a cut above the rest, which is why I kept returning to him for additional batteries, two solar geysers and now waiting on an aircon install.
I really like the way you had the Pylontech’s mounted. Apart from saving space, any other reason why on their side like that?
My garage angles downwards towards that wall… And I have already had my fair share of water issues in there. I think having it off the floor is great idea! :-D. (Obviously not the technical answer.)
Very nice setup Jarrett! And Jaco, kudos for that installation, it seems top notch workmanship.
Jarrett, where are you based? Our setups are very much alike save for the fact that I have only 6 x 410’s yet, and operate with a 200Ah lead acid bank.
I hope to have 6 more panels by March/April next year.
Would like to compare data/figures in the future. It felt like looking at my own data with your first pic, our microwave or air fryer does the same.
your system looks great, guess Jaco’s boys are smiling as it was an easy job for them to install your panels compared to my double storey “slippery” tile roof with the winds at 30 plus kph
Hey @Swartkat. Thanks. We are based in Kenilworth. Lovely rainy day!
At the moment I am manually recording the daily prepaid meter values. I’ll share the sheet later. We only have the oven off the solar setup. Would be good to compare data for sure .
As for the Victron info, will see how to share that. Have not had the time for custom IoT stuff. But looking at putting that data somewhere to analyse. Saw this project https://github.com/victronenergy/venus-docker-grafana.
That’s a higher grade question I can’t answer @Rautenk. But on the hardware I can say my budget was very restricted. And passing this project past the government(wife) went through lots of red tape haha
But simulating load shedding and seeing about 1-2 units being used a day is kind of cool. Does need some change in the way we live daily to achieve max ROI, but we will get there. Government is very impressed.
For interest sake (and if I can get my PVSyst to work), I will run a quick modelling exercise to see what the effect is. Haven’t done it specifically for Victron, battery coupled… Will post on this forum to show if there is a difference.
hi @jarrettj, I have a NE and NW roof, Jaco installed 6 panels on the NE roof and 6 panels on the NW roof ( 355 watts each ), the system hits 3600 plus watts max for the day, and stays in the 3000 watts plus range for a good part of the day this is with ONE 250/70 mppt
If you go to the NW & NW facing panels article from about ten days ago, there is an article in my post that talks about the loss being less than ONE percent
Hi @Rautenk, all of these factors as well as some other forums post as well as discussions with Victron made me decide that with the available budget , this would be the best way to go.
What we saw on other sites is that having an East & West array on the same MPPT is working pretty well, just refrain from having Panels from the same string in different directions, that messes up the strings production completely.
Will look up that article, thanks. Added details on MPPT to original post. Will have to get back to you on my averages etc. Probably around 2500, but I am guessing here haha.
And there it is … this is the teeny weeny tiny little titbit that must be carefully considered when connecting different facing arrays on the same MPPT.
Indeed, if you go East/West, or even NE/NW, you need both sides to run at the same voltage (ie same panels, same series/parallel config), ie they have to mirror one another.
What happens is that the lower side cannot make power at the voltage that favours the stronger string (the one the MPPT found by trial and error),so you certainly don’t want to introduce a difference in voltage by using dissimilar arrays.
Also, putting part of your panels in a series string into a different direction is just idiocy. The current will drop down to what the panel with the least light makes… it will kill the entire thing
