Will be in the upcoming v2.62 patch release. You can already install 2.62~4 if you want. But I don’t think it is available to non-support persons as download or via VRM. At least not yet. You can however look for it yourself on dbus. It’s on com.victronenergy.vebus.whatever at /Devices/0/ExtendStatus/PowerPackPreOverload.
My suggestion is not to change everything at once. If something is not working then you don’t know what change to look at. Make your changes in increments and test each one. Possibly keep to 2.60 until everything else is confirmed working
I’m running the Latest Release Candidate versions, so it is fine.
BUT, before I remove the Daly, want to see WHAT is recorded on the Venus, like is/was it me, was it indeed the 60v max the BMS can do … did I miss anything else?
Excellent. Know how to get there.
Bummer is, one release behind … and I had DC Ripple a couple of days ago.
So will update today and wait for another DC Ripple.
I swear I said that some time in the past (in the context of installers arriving on site, upgrading all the firmware at once… and then blaming the wrong component for some “new behaviour”)
… and then plug the RS485 USB converter into the Venus USB port?
Question: If I just connect to the Venus, it ain’t gonna affect current settings right?
Just see if I can see the info displayed, then disconnect again ASAP, no, yes?
Or is it better I wait for the SD card to arrive tomorrow, and do then do it on the Venus Rpi version?
If you’re thinking DC ripple… nope, this won’t reflect here. This is that other issue where the inverter shuts down due to overload while grid connected.
DC ripple is very simple to explain. When the battery disconnects from the DC bus (for whatever reason), only the capacitors on the DC bus holds things steady, and they cannot do it. The 50Hz generated on the AC side starts to pull the DC side along and a 100Hz ripple shows up. The more power going through there, the more pronounced the amplitude of this ripple.
The ripple is merely a result of something else. Not the cause.
If the serial battery driver on the Venus does see your BMS when you plug it in, then it will use the settings from the BMS instead of the Venus. So you charge values will be from the serial battery
If your Battery Monitor is on Auto like in the picture below it will use the BMS values when available and fall back on the old stuff when not.
The one thing that you might have to reset manually is your MPPTs. They will go to the yellow light when the BMS is missing. You will have to log on using your phone and just follow the prompts to reset it to continue without BMS like before.
Edit: And yes you just plug that USB converter into the GX
Might be better to do all this on your test Pi Venus if this is not going to be part of your current setup yet. Else the BMS will tell the MPPTs to do full charge while the real battery that is currently is in use if full and it will trip.
100% … misunderstood that maybe I can see something. Will move on as my gut says to me that it is the BMS I have …
Ok, thread derailment START …
O I have a client that has that EXACT problem … he is now off-grid till a solution can be found.
Like 250w powered from the inverter and batts, no other loads as the house is sleeping, the inverter will shut down due to overload.
First, the problem surfaced as DC Ripples, bad ones, as the inverter switched off.
Then the cables were severely shortened AND the battery bank was returned for a refund.
A new Revov 11kWh one installed.
And Revov engineers found all 100% spot on ito setup and connections.
Not the cabling and not the BMS nor the batts …
In the end, the DC Ripples left the building … but was replaced with a severe inverter Overload, switching all off.
The client is currently off-grid, although he bought the system to be grid-tied.
If anyone wants to test with this client, generating some substantial cudo’s for Victron support in identifying the core cause, drop me a PM, will put the parties in contact.
BTTF remains a favourite. Even if I’ve seen it 27 times.
It looks as if the DC ripple coincides with low battery. That could of course also happen. A very low battery (or a load that is too much for the battery capacity, or a high impedance link somewhere) could also cause DC ripple. In the end, V=IR (volts equal amps times resistance). If the amps have a 100Hz cycle on them, then a high ripple in V means you have a high R somewhere.
