Have you tried to reset it and re-add to network? I had a bit of trouble getting mine connected initially, but super stable afterwards. My wifi was terrible at the time, so blamed that.
LS throws a lot down the lines when power is restored.
All these “new” devices with hi-tech possibilities are not designed for No 1. They need clean power.
Bugger.
Sparkie must come now and install this: 12-01036 - Tripconnect 1P | Clearline Store
To keep the power away from the house for as long as it can, after Eskom LS is over. Also to protect the inverter before it syncs with Eskom.
@bexacom may be an idea to import them too?
Found one in Greece for R540 delivered to an address in Greece. Maybe having two brought in.
ESP12S is easier to put on. With the ESP12F you need 2x additional resistors, one super tiny. With the ESP12S it is a drop-in replacement without any additional components required, because those pins are pulled down by default in the ESP12S already.
