Looking for Python code to read them. it seems their “math” is a bit not clear, there is python code to read the normal hall effect, but you need to tell the Python how to intrepid the “clicks” it’s getting from sensor to L/min flow.
plan is to connect 2 of these onto a RPi zero located close to the 2 water tanks, going to measure water in from council and then water flowing out to booster pump into house.
Specification:
Product Model: B10 Product Name
Model YF-B10: Product Name
Rated voltage: DC=5V inspection standard
Appearance Product identification is clear, accurate and correct
Water pressure: resistance >1.75MPa
working voltage range: DC5 ~ 15V
insulation resistance: >100MΩ
Accuracy: [in 1~25LMIN]±5%
Flow pulse characteristics: (6*Q-8) Q=L/Min±5%
Output pulse high level: > DC 4.7V (input voltage DC 5V)
output pulse duty cycle: 50% ± 10%
(as per other thread, also adding a water level sensor, and then looking for solution still to do water pressure on lines).
