Do anyone have a unused shunt they want to get rid off?
I’m looking for a 150A-200A shunt and con only find 100A models or very expensive ones on RS-Online
Victron has a 500A/50mV shunt only, about R500 + VAT retail.
I have a Victron 500A shunt in a less than optimal condition. It was installed in a box outside where moisture got to it and corroded things. I’m sure the shunt itself is fine, but the little green PCB on the side is not in the best condition. One of the fins also looks as if it’s had a knock to it, though it doesn’t look like it would affect the operation.
You’re welcome to it, if you want to take a chance…
That sounds perfect for what I need. Thanks
