Any type of lighting with a standard connector (not strip LEDs)
look through here - mostly down lighters. If you search for “MR16 LED” you should get some 12V LED options for the down/spot lights instead of Halogen. If you look through the outdoor options you will also find 12/24V LED security/flood lights.
I purchased from them once before, received my products, and also had a refund processed for an out-of-stock item.
