Hi all
I use to use the following topic to determine if the grid is connected or not?
Has this changed, whats a good dependable topic to use.
N//vebus/261/Alarms/GridLost
made decision on if value is 0 (grid=yes) or not 0 (grid=no//fail/load shedding)
G
Hi @georgelza
I use: N/XXXX/vebus/276/Ac/ActiveIn/L1/F
If frequency is 0 then Grid is down.
Regards
Mark
strangely i got some flows that work… but when i go mqtt explorer i see nothing pass N/XXXX, there is no vebus sub dir structure.
is this a VERY short lived structure ?
G
My value is Retained
Look for the Multiplus and use this value…?
… left mqtt explorer open, it came, there was bucket loads of topics and then it was like someone took a eraser and started cleaning out… strange.
how’s the TTL/persistence of your topics/values?
G
… more data point… while i’m watching the VRM web interface, it seems to populate the mqtt broker with values, if i navigate away it seems to say, you not looking so i’m not posting.
arggg… strange…
@plonkster ? did i break something ?
G
Correct. It has an inactivity timer and it stops sending keepalives if you’re not watching it on VRM. You have to send your own periodic keepalives.
so i was publishing a current date/time to R//system/0/Serial as a keep alive… from node_red
what would be a better keep alive,
G
Just publish a blank payload to that topic and it should remain alive.
Venus 3.00 has some fixes to that too.
Inject every 30s … Works for me and may not be perfect I know
… so i’ve got the keep alive configured in node-red to keep that connect from it alive with the VRM/mqtt broker…
and then i have various node red flows consuming from VRM/broker.
but still it is as if if i don’t open VRM web interface then these flows are unstable, no dependable.
G
am i expecting it to do something that it’s not to do.
my keep alive in node red i assume will keep those flows working, even when the node red page is closed.
G
