Hi Guys.
I need information . I am currently running a 250/100 victron smart Mppt VE.CAN charge controller. My question is can I connect a 150/70 victron blue solar Mppt charge controller to the 250/100 using the VE.CAN connection.
Hi Guys.
It is not quite clear what you’re trying to do.
If you want to daisy-chain another VE.Can MPPT off the first in order to connect it to a GX device… then yes, of course you can do it. Simply move the CAN-bus terminator to the next MPPT and plug in a cable. Done.
If you want to know if you can network the two MPPTs (using VictronConnect), I believe you can do that too. I’ve never done it, but I believe it is quite possible.
