Victron ESS - Scheduled Charging
I’m getting too old for that. :slight_smile:
That feature uses Eskom. Which makes perfect sense, I made another plan.
Using the Venus Large OS … Release Candidate and all that. :slight_smile:
“There, I fixed it” - keep inverter max W to what the panels can do for bad weather.
And the SOC - to increase it, again, for bad weather:
And I worked around the SOC of 100%, set it to Keep Charged instead without using Eskom, so that the house benefits from the panels, and the batts are kept nicely in place for anytime LS and evening use, even with LS.
