The order isn’t really all that important. It’s a low frequency design, it’s not really going to matter.
The only thing that I think is important is to shut down the inverter before removing the DC power. Or you may find (like my friend @TheTerribleTriplet) that the Multi keeps in running without the battery (cause the solar chargers are still working). But again, if it is an emergency and you have smoking cables… forget about all that. Inverter is very unlikely to be damaged… pull the DC disconnect.
This seems to be the thread for my issue. No emergency though.
I’m planning on adding a 2nd critical load DB on the AC1 out and I suppose that terminal bites.
Just need to connect and route live and neutral wires of about two meters from the inverter to the new one.
Will the inverter be ok if I just switch it off at the rocker switch at the bottom? I will switch the 1st critical loads DB back to Eskom before I shut the inverter down.
Or do I need to do something else too?
So this is what I had in mind to do:
Switch current critical loads to Eskom with the changeover switch
Shut down grid power to the inverter
Switch it of
Just want a avoid a situation where settings are lost, or everything needs to be set up again etc.
Oh yes and one last question.
The 2nd critical load DB will have its own neutral bar, but these circuits will obviously be “connected” with the neutrals in the in the 1st critical load DB through the inverter. Is this fine?
Sorry for dumbass questions, this is not my day job.
Thanks Jaco, I’m halfway there. Just waiting for an extra neutral bar to inserted in the 2nd critical db and then I should be good. It currently only has a neutral bar for the non critical loads.
I suppose to comply with regulations, this db should also have its own earth leakage. Sigh, the price for comfort.
But at least my garage door, lights, plugs and gate motor will now also benefit from solar.
