Hi all
I have no experience with Pylon batteries.
Will it be safe / recommended / fine to use a Pylon UP2500 24v battery on a inverter with no BMS communication between the inverter and battery?
So far the plan is a Victron Sun Inverter 24v with around 350W of PV and only 1 Pylon UP2500 connected to it.
Granted of course I set the charge parameters correctly and with this config it will never get even close to the max 50A charge and discharge current, will this battery be fine to manage itself over time and will it last?
P.S Yes I know I can connect a GX to that inverter and do things “properly” but budget, plus for this little system a fully fledged GX even a Venus PI at todays prices and availability will be total overkill.
BTW I’m also open to other battery suggestions, preferably a single 24v unit, need at least 2 kWh capacity.
