Need some help here please as I’m stuck.
I use 3 routers currently all hardwired to each other.
The normal router supplied with your incoming fibre line (Huawei);
this then connects to no.2 below -
Telkom D-Link (not via direct network cable, but through those wall socket TP-Link
devices that uses electricity lines) which in another part of the house connects to a -
An older version Telkom D-Link. From this router I have a direct network cable to the Venus in the garage.
So my remote console is via a dedicated old old old laptop that wifi connects to this last router which works perfectly most of the time - sometimes the Venus will randomly just change its IP address and I have to find the new one with the Victron connect app and put it in the laptop for it to work again. Not a big issue but it may hint towards the problem I’m experiencing.
- So I recently I acquired another router (a TP-Link) which I want to add in this chain (which
must now be the one to which the Venus must connect to with network cable. The
dedicated old laptop must also then connect to this one via wifi.
So basically, I want wifi in the garage now with the use of router no 4.
Connected it in the garage, had a friend sort out the IP address stuff and all that goes with it (or did he???), gave this wifi its own name, and it worked. For about an hour…
I tried removing this network and adding it again, and it worked once more.
Thereafter it refuses to even allow me to connect to it. The strange thing is, our cell phones and my other laptops does connect to it.
Granted, the laptop is very old and have not been updated in years, but this old laptop does connect to both the other 2 wifi routers in the chain with no problem.
Also noteworthy is mentioning that when trying to connect to this last router with the old laptop, it wants a network key/pincode that is printed on the bottom of it (despite it being configured with a password for this new network. (it doesn’t allow you to enter the password, it wants numbers only)
Now when I use my newer laptop to connect, it also asks for the network key/pincode (which it states its wrong when so entered), but allows you to enter the password, and accepts it.
I am out of ideas. My first thought would be that it might be clashing IP addresses, and I have no idea which routers has static or dynamic addresses and if this is an issue, or whether the issue lies with the old laptop (bearing in mind that it has no problem to connect to any of the other routers.
The message I get when attempting to select this new network from the old laptop states “The settings saved on this computer for the network do not match the requirements of the network”
Currently each router has its own name and wifi password. Should I rather look at making at one big network with the same IP address and one password?
Any ideas on where to start troubleshooting?
