I need to know the decimal after the SoC, so I use the BMV SOC.
Can only switch to Min ESS SoC of 85% if BMV SoC is a min 85.1 %.
Next level:
Automate this process using a SOC setting in the system that gives a decimal %, and up the SoC to 0.1% less than that 5% bands up to a max SoC of 85%, for late afternoon it tops up to close to 100%.
Just a genuine question: why would you want to automate adjustment of SoC? Only example I can think of is when you’re integrated with the Muni’s (admittedly inaccurate) load shedding schedule? What am I missing?
Over time I have noticed, being in Cpt to boot, that I don’t:
want geysers to be heated by batteries,
want to draw huge amps out of the batteries during other times.
want to use batteries during cooking times, evenings nor mornings.
Heat batteries any more during peak ambient temp hours due to large loads powered.
I prefer to spread the loads over 24hours.
So from 10pm:
set the Min SoC to 30% in summer, winter maybe 50%.
reduce the inverter watts to 800,
9am (tuned per season) I up the inverter watts back to 3.7kw to give the batts a little headstart, and skipping peak morning usage.
All automated already.
So by upping the SoC slowly I can get at ±10am to about +80% SOC when the first geysers starts.
Say it is 90% SoC, so what, use some of the batts, it is ok, but not below 80%.
2nd geysers starts at 1pm, by then I want to be at about 85%.
Both geysers stay on till 5pm, so use some batts if they must.
So by 3pm I aim for 90%+ SoC.
Then late afternoon I have the system on a Scheduled charge to not use any batts, as the SoC should then be reaching 95%+, ready for evening use, or at least min of 90%.
Here is a good example of what I am trying to do, peak cooking times are on Eskom for the cost to take that off the grid is 2 x 5kva MPII and doubling of the battery bank, the batts a Hobby, not a Need.
Ditto … maximum cycles over their lifetime steering well clear of any consistent temp increases because no matter lithiums or lead acid, consistent high temperatures kill batteries prematurely.
So charge them hard when the ambient temp is reasonable and use them lightly when the ambient temps tend to be higher, for being grid tied, peak hour loads should be 100% from the panels in any case.
That makes perfect sense, thank you for the very detailed reply. I would desperately like to implement the same scenario with my system, but because Goodwe, it does a restart whenever you change any of it’s parameters (like min SoC). The driver we developed allows us to make such changes but the inverter restarting every time is annoying. As it is I’m already dealing with random restarts (a looooong saga in itself).
I think I have achieved the result you are looking for using rules in HA.
I charge my PylonTechs in the mornings using all the power the PV array can generate to keep the battery temps as low as possible early in the day.
I then have a rule that turns my geyser on at 93% SOC. The geyser will continue to run unless the PV array output has dropped below a threshold or the SOC has dropped below 91%.
I have scheduled the geyser to switch on several times during the day and run on a loop until 3PM at which time it will turn off and the array will top up the battery bank to 99% SOC before the sun sets.
My solution is unfortunately several rules in HA and certainly not as elegant as the solution you are seeking but it works very well for me.
My personal idea is just to shift the 20% odd Eskom power that I use every month to the early evenings rather than early mornings.
I live in an area which is prone to power outages (outside of Loadshedding unfortunately). This way I have batteries almost fully charged when I’m awake and have ample time to react should I have a power failure early evenings (busy automating that part too - switching off loads based on priority and SOC).
And if I have a power failure early morning I have enough batteries to get me to sunrise.
Granted it isn’t sunny every day, but at least it gives me some backup.
I’ve got to like 15% in summer on 3.5kw panels. And if we don’t cook at night, then maybe I can get lower … BUT … now I have 4.2kw so we will see this summer.
But we still cook at night … with computers and other media for entertainment at night … maybe I must … naaa, I ain’t gonna go there, I like my life.
It is 9:58am and geyser one is going to come on at 10am.
Because I allow the batts to gain some charge the SoC is now on 67% having powered the normal loads the whole morning as seen above. So this is 9:58am:
And then at 10am and geyser one came on. If it was not a nice day I would not want to use any batteries.
And if the system must, I have already set the Min SOC to 65%, in this scenario, only 2% of the batts will be used, which is a “so what” case.
And by 10h30, the batts have gained some charge, whilst the 2kw geyser and ±450w other loads where powered. At 70.1% SoC I set Min SoC to 70% - slowly building up to about 85% SoC.
Waiting for 70.1%, BMV SoC at 69.7% as I don’t want Eskom to interfere with MPPT doing it’s thing.
- alias: Set ESS Min SoC Automatically
trigger:
platform: time_pattern
minutes: /5
condition:
condition: and
conditions:
- condition: sun
before: sunset
before_offset: +00:30:00
- condition: sun
after: sunrise
after_offset: -00:30:00
- condition: state
entity_id: sensor.bmv_soc
state: '36'
action:
service: modbus.write_register
data_template:
unit: 100
value: '{{ states(35)|int * 10 }}'
hub: victron
address: 2901
Thing is to do this:
sensor.bmv_soc = 36 then modbus.write_register = 35
sensor.bmv_soc = 41 then modbus.write_register = 40
sensor.bmv_soc = 46 then modbus.write_register = 45
etc
