What would happen if you were to put two independent Axpert inverters on the same DC bus?
Here’s the scenario:
We have an Axpert 5kW inverter at the office (Kodak OG 5.48) that has 3.5kW of solar panels and is connected to 4 x US2000 batteries (soon to be 7 x US2000). There’s no communication between the inverter and batteries (nor between the batteries), and the inverter is set to SUB (solar-utility-battery) mode, so it only dips into the battery when there’s loadshedding and insufficient solar.
The 5kW currently available is proving to be a bit limiting, so we’re contemplating adding another 5kW (because it is cheaper than buying a 10kW inverter). The problem is these inverters cannot be paralleled, so the idea is to just connect them both to the same DC bus, and split the loads more-or-less equally on their outputs.
Is this a non-starter? If not, are there any special considerations if we were to go this route?
