Tips 4 consulting rooms expansion
Hi, we refurbish an existing well-built 5 bedroom residential home for use by medical practitioners, no procedure room. I contemplate getting a 300L vacuum tube geyser and heat pumps and to extend the current 8kw Sunsynk with 2x5kw lifepo4 with another 5kW battery and add 5kW PV string to the existing 4.7kW panels, any tips and guidance will be appreciated
Regards Gabriël
I presume these will be different from the installed ones?
How will you wire them?
Hi Richard, the 4.7 are on one string, so i will add another string of about the same size in order to fully utilize the inverter capacity.
