Tian Power BMS
Thank you all for sharing your experiences.
How about SolaX products, are they any good?
Pylontech uses Lithium Ion cells. LiFePo4 cells are better, yes?
They use LiFePO4, just like the other guys.
Sample quantity of one user here, that said BYD perfect so far. LifePO4 cells, got two towers with 4 banks each.
Hello.
my narada BMS use TP1633, i has try your software, all i can read, but capacity i cant edit it.
Showing: Set capacity fail,.
I also input password (123456, 123456789) before set capacity but it not work.
Please help me.
Thank you bros
I’ve try it. Unfortunately the BMS does not communicated. Need some advice
Is there anyone known contact sales Tian Power BMS ?
Hi please provide BMS monitoring software. tian BMS
Tian Power BMS
Hello Stanley and others,
I have recently bought two Shoto batteries from a vendor who I tired to get the software and modbus communication protocol, but they ignore my emails, and saying that they can not share the software!
I managed to read shoto batteries with Tian-power software, V1.1
In version V1.1 the modbus start with 7C not 7E,
In this software you have shared the modbus protocol starts from 7E, which is the start of a message (just a standard). The advange of the version that Stanely has shared here is that the config tab and parameter tab is open for to be used, can anybody by chance know or have any other version of Tian power that starts with 7C (that also have open config tab).
I would like to change some parameters in bms, which simpliy I do not have access now!
references:
https://powerforum.co.za/topic/13120-narada-npfc-tian-power-bms-protocol/
my test with Tian power software v1.1
7C 00 01 00 00 0D read data
7C 00 33 00 E0 0D read bms version
7C 00 42 00 80 0D **Read PCB **
I have a goal to take all codes out if you could help me,
Cheers,
Kaveh
