Are there any products on the market that you can install to only let in a preset amount of water into the bath once the tap is opened? If it resets once the tap is closed that would be perfect.
Alternatives would be a timer or a bath with an inbuilt float valve somehow…
Sometimes the install doesn’t allow for a neat overflow, or the overflow is slower than the rate of water coming in.
This is for a new bathtub install. It’s going to be a freestanding bath, in a bedroom, upstairs, on a wooden floor. An overflow is the last thing I want, looking for a smart way to make it almost impossible.
Maybe something like a solenoid value coupled with a sensor at a certain level in the tub could work (in the hole where the overflow would be? Then at least you can cut off the water once it reaches the “full” level?
Great idea! You might need to adjust the pressure switch to get the correct level… (They are preset for a particular pressure equivalent to a depth of water…)
