Hi everyone. I’m busy investigating setting up a solar system at my place. I have a few challenges, including the majority of my roof currently being taken up by my pool heating system, limiting the amount of space available for panels.
I currently use between 600 - 700 kwH per month and had been planning on around 7kw if panels, a Sunsynk 5/8 kW inverter and starting off with around 6kwH of lithium battery storage. I’ve had an installer out who’s provided me with the following quotes (and is advocating I use EVO batteries).
I’m looking for guidance from more experienced forumites on the costs, the total panel sizes he’s recommended and whether this is an install you’d take up?.
8kw Sunsynk inverter, 1 5.7kwH Evo battery
2x 5kw Growatt inverters, 2 x Evo 5.7 kWh batteries
The only info on the Evo batteries I have is what’s on the attached spec sheet, I’ve been unable to find info online.
EVO5.7V-1.2.pdf (379.3 KB)
Installer has offered to swop out the Evo batteries for Hubble (which was my original choice) in six months time if I’m not satisfied with them.
Thoughts? Advice?
