Pylontech UP2500 Latest Firmware
Can Anybody help or have the latest Pylontech UP2500 firmware
As I contacted Pylontech 3 days ago and still no reply from them
Thank You
Charl
They sometimes take a few days to respond. You need to send them the serial number of the batteries so they can determine the latest firmware for that hardware revision. (Not sure about the UP2500, but there are two hardware revisions for the USx000C series.)
I have also read on another forum that someone’s request for firmware was rejected, because there was no valid reason for updating the firmware. If you state that you’re experiencing some kind of compatibility issue, or you’re adding new batteries to an old stack and would like to avoid any issues, then in my experience they have no problem sending you the firmware.
Thanks for the reply PierreJ
I have send them the serial numbers and the issue I have.
The version at the moment on the Pylons v1.1
The BMS is not displaying cell temp correct max cell and low cell all minus values
But in Batteryview it’s correct.
