how did you interface to the modbus interface ?
G
G
Using this integration: GitHub - sfstar/hass-victron: Integration for Home Assistant to fetch data from the victron gx device via modbusTCP
let me ask different, did you connect a physical RS485 dev board to the RS485 port on the victron ?
assume RS485 connected to the HA ?
G
Sorry George - missed that part. I run a CerboGX and connect to the Cerbo Modbus using the integration above from a Home Assistant instance on a Pi. The above sensors are then available on the HA to use on the Energy Dashboard.
Let me stop there… that’s about as far as I can go without running out of knowledge…
You all know that Victron now has Forecasting and that you can get that data via the new Victron VRM API?
It was posted on this forum before.
Just wondering.
… actually found I previously deployed some code in NodeRed that does Modbus calls to the victron… so it’s been lying there, simply not used,
I’m changing my source from MQTT → Modbus.
G
did not know… but this is in victron. i want it inside HA.
G
https://vrm-api-docs.victronenergy.com/#/
Here you go:
anyone have a idea why i’m not showing forecast day 2 etc.
I have Solcast installed
2nd question, how can I stretch the image to fill a page, I pasted code into a vertical stack card, alternate suggestion appreciated.
@Sc00bs - this is “copy” from your dashboard, porting it to fit into my Victron based system… about now where those generic naming of values would be loved
you also use a entity:
- entity: sensor.solcast_forecast_remaining_today_every_minute
This does not show in available entities for solcast ?
You need to update the apex code.
Should look something like this:
- entity: sensor.forecast_today
name: Solar Forecast (D1)
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
var today = entity.attributes.detailedForecast.map((start, index) => {
return [new Date(start["period_start"]).getTime(), entity.attributes.detailedForecast[index]["pv_estimate"]*2];
var data = today
return data;
Emphasis on: var today = entity.attributes.detailedForecast.map((start, index) => {
You probably not having detailedForecast in there.
if you don’t mind,
type: custom:apexcharts-card
view_layout:
grid-area: solar
header:
show: true
standard_format: true
show_states: true
colorize_states: true
apex_config:
chart:
height: 250px
tooltip:
enabled: true
shared: true
followCursor: true
graph_span: 4d
now:
show: true
label: Now
span:
start: day
offset: '-1day'
all_series_config:
type: area
opacity: 0.3
stroke_width: 1
series:
- entity: sensor.soc
float_precision: 0
type: line
color: '#f06292'
opacity: 0.6
yaxis_id: capacity
extend_to: now
show:
legend_value: true
in_header: false
group_by:
func: last
duration: 5m
- entity: sensor.solar_yield
float_precision: 3
color: '#ff9800'
yaxis_id: kWh
unit: kW
transform: return x/1000;
extend_to: now
show:
legend_value: true
in_header: false
group_by:
func: avg
duration: 5m
- entity: sensor.peak_forecast_today
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.period_start), entry.pv_estimate];
- entity: sensor.peak_forecast_tomorrow
name: Solar Forecast (D2)
float_precision: 3
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
- entity: sensor.forecast_d3
name: Solar Forecast (D3)
float_precision: 3
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
yaxis_id: header_only
color: grey
show:
legend_value: true
in_header: true
in_chart: false
data_generator: |
var data = today
return data;
- entity: sensor.forecast_remaining_today
name: Forecast (D1 Remaining)
color: grey
show:
legend_value: true
in_header: true
in_chart: false
data_generator: |
var data = today
return data;
- entity: sensor.forecast_tomorrow
color: grey
show:
legend_value: true
in_header: true
in_chart: false
color: grey
show:
legend_value: true
in_header: true
in_chart: false
- entity: sensor.api_last_polled
name: Forecast (Last Update)
color: grey
unit: ' min.'
transform: return ((Date.now()) - (new Date(x).getTime())) / 60 / 60 / 24
show:
legend_value: true
in_header: true
in_chart: false
yaxis:
- id: capacity
show: true
opposite: true
decimals: 0
max: 100
min: 0
apex_config:
tickAmount: 5
- id: kWh
show: true
min: 0
apex_config:
tickAmount: 5
- id: header_only
show: false
So you see you have a couple of different lines reading:
data_generator: |
That needs to change to
return today;
Or you can do this (not tested by me):
data_generator: |
return entity.attributes.detailedForecast.map((entry) => {
return [new Date(entry.period_start), entry.pv_estimate*2];
You need to do the change for each one.
changed to:
resulting in:
type: vertical-stack
cards:
- type: custom:apexcharts-card
view_layout:
grid-area: solar
header:
show: true
show_states: true
apex_config:
chart:
height: 250px
tooltip:
enabled: true
shared: true
followCursor: true
graph_span: 4d
now:
show: true
label: Now
span:
start: day
offset: '-1day'
all_series_config:
type: area
opacity: 0.3
stroke_width: 1
series:
float_precision: 0
type: line
color: '#f06292'
opacity: 0.6
yaxis_id: capacity
extend_to: now
show:
legend_value: true
in_header: false
group_by:
func: last
duration: 5m
float_precision: 3
color: '#ff9800'
yaxis_id: kWh
unit: kW
extend_to: now
show:
legend_value: true
in_header: false
group_by:
func: avg
duration: 5m
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
return today;
float_precision: 3
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
return today;
float_precision: 3
extend_to: false
color: grey
opacity: 0.3
stroke_width: 0
yaxis_id: kWh
show:
legend_value: false
in_header: false
data_generator: |
return today;
color: grey
show:
legend_value: true
in_header: true
in_chart: false
data_generator: |
return today;
color: grey
show:
legend_value: true
in_header: true
in_chart: false
color: grey
show:
legend_value: true
in_header: true
in_chart: false
data_generator: |
var data = today
return data;
color: grey
show:
legend_value: true
in_header: true
in_chart: false
data_generator: |
var data = today
return data;
color: grey
unit: ' min.'
show:
legend_value: true
in_header: true
in_chart: false
yaxis:
- id: capacity
show: true
opposite: true
decimals: 0
max: 100
min: 0
apex_config:
tickAmount: 5
- id: kWh
show: true
min: 0
apex_config:
tickAmount: 5
- id: header_only
show: false
header:
show: true
title: PV Potential (Today)
show_states: true
graph_span: 12h
span:
start: day
offset: +6h
series:
- entity: sensor.tinman_east
float_precision: 0
type: line
color: '#f06210'
opacity: 0.6
yaxis_id: capacity
extend_to: now
show:
legend_value: true
in_header: false
- entity: sensor.tinman_north
float_precision: 0
type: line
color: '#f06292'
opacity: 0.6
yaxis_id: capacity
extend_to: now
show:
legend_value: true
in_header: false
