if i split the cat5e as in diagram each ipc gets power and data… your comment pse
this could have bearing on @Phil.g00 s planned setup as it will save on cabling
nb my setup uses max 40m at 100mbps with cat5 or cat5e
EDIT: THE IMAGE REGARDING POE WIRING MODE-B IS UNTESTED! I WILL POST AS SOON AS I HAVE SUCCESSFULLY WIRED A CONNECTION LIKE THIS!
this is on info as per this
