Nissan Leaf Lithium pack or cells available 25ah cells Lithium-Ion 3.7v per cell 7.4v per module
or sale Nissan leaf battery for sale comes as 96 cells or 48 modules each module is 2series1p 7.4v .
For the Diyer this would be super as they can add built portable storage and works great in 14s for 48v .
Cells are supplied in Johannesburg can be sold as a lot and or sold as individual cells .
Total of 2 packs with 48 Modules in each ( 96 cells in each pack ) 96 modules being offered .
200 Rands each module Estimated 25ah useable . 7 modules makes a pack 1.3Kwh (14 modules makes 2.6kwh etc)
price drop 120 ZAR per cell have lots available
Edit Price drop again 100 Rand per Module (2cells )
Hello! Maybe it would be a little clearer if you simply wrote the specs like a tree:
1 pack has x modules
1 module has x cells
1 cell is x V and y Ah = z kWh for R 120
thanks for the suggestion .
I no longer have packs available ( have stripped the batteries into cells)
1 Module has 2 cells in series . 3.7v + 3.7v total 7.4 volts With a cell tap in the middle on the cell module for monitoring each cell with a bms .
1 module is 3.7v x 2 and 25ah = 185whrs .
Normally built into a 14s3p arrangement for 48v would mean a 7.7Kwh battery for R5040
This is great. Thanks for considering the input.
Can the modules be disassembled into the individual cells? Or at least being left with usable cells post disassembly? Even if just to rewire into a parallel arrangement.
sorry been abit busy , They can be connected in parallel arrangement easily . You can also tap into the center if you wish to only use one cell say in an arrangement where 24v is required this wont be necessary as 7s ncm works well.
In 48v application it would be an ideal for 13s configuration . Ive built a few of these and they work really well using a 4parallel arrangement . We built a 7kwh battery with this on a Kodak 48 worked well 45.5v cut off for discharge and 53.3v charge cut off .Still both values with headroom to go either way as a conservative figure
This is quite helpful! What BMS have you used in your builds?
you could use a JK bms or a daly bms both will work suitably . on our build i used our own bms that i designed but this is not for public consumption .
Price dropped to 100 rand per module with 2 cells in each module .
Hi
How many modules do you have left and can
you provide the dimensions of modules or individual cells. Any idea what’s the chemistry of the cells?
Lastly, where in jhb are you
Cells are NMC chemistry of sorts not 100% sure as nissan dont give too many specifics . *
cell make and model = AESC 32.5Ah
We have 188 modules remaining . 376 Cells . 34.7Kwh of energy storage.
Located in JHB north .
