Also, just so you guys know how big of an influence you have… this forum was a source of some of the info used in the implementation. When the question came up late one night (is there an API?), I could point my colleagues right here. You guys are awesome.
Unfortunately there’s a bug somewhere, and I’m not exactly sure where to next. Please see the two attached screenshots. (error: “Request failed with status code 429”)
It would be great if someone could please give some advice?
I’ve had the same problem. It’s because you’ve used up your 50 API requests a day (you can also see that with the 1/50 under the node). It’s because entering your area does a search as you type which only happens when you enter the API key before entering your area. I eventually found it in the documentation:
If you don’t want to use API quota by searching, and you already know the id of the area, fill out the area first and then the license key.
In my case I just left it until 12am and then it resets and carries on as usual.
Will this only report the current load shedding stage? If the stage is going to change from stage 4 to stage 6 at 4pm and we want to have our batteries ready how would that be done?
