One of my friends imported 2 of them 2 weeks ago. He had snap chance grabbing 2 online before they were gone. We got a whatsapp group with friends that are running shelly stuff and we do sometimes do a group buy if we need stuff from them.
Nothing can really happened between network cable and power cable. Both are sealed in plastic. I have seen for years network cabling running next to AC cable in trunking and the buildings is still standing. Stress more about the AC cable getting loose on your terminal blocks and trip switches in your DB.
Heh, the issue is more a concern about inductive coupling between AC mains and the network cable. There’s a good reason why you don’t run AC and Comms in the same conduits. Outside of the safety factor (high voltage present on low voltage cable due to cable insulation breaking down) the other issue is surges (like a lightning strike) on incoming AC inducing damaging voltages on the Ethernet side. It’s for this specific reason WiFi works so well in this case, as there’s no risk of damage to your network when things go wrong.
I doubt it has overload protection, so it cannot be the breaker. Also, I think regulations say the switches must be readily accessible, and having to tap through a touch screen or taking out your phone and joining the WiFi network first would probably not qualify
