Introducing 12v 100Ah,200Ah and 300ah with BMS!
Prices as follows :
100Ah - $200
200Ah - $300
300Ah - $400
Prices includes shipping to our Warehouse in South Africa
For more information feel free to contact me
Email : Johnathan@apexiumtech.com
Prices as follows :
100Ah - $200
200Ah - $300
300Ah - $400
Can you post a spec sheet with BMS make and model please?
@mmaritz thank you for responding
Here is the specs, it is our Apexium BMS
Rated Voltage | 12.8V |
Rated Capacity | 100Ah |
Combination | 4S1P |
Cells model | EVE LF100LA |
Consistent discharge current | ≤50A |
Max. pulse discharge current | ≤100A |
Charge Temperature | 0~45℃ |
Discharge Temperature | -20~60℃ |
Communication | RS485,Bluetooth |
Size | 32.917.221.4(CM) |
Weight | 12KG |
Apexium 100Ah BMS Specs :
Model | 16S 100A |
Battery type and serial number | LFP(16S/15S) |
Version | 10E V16 |
Continuously charging/discharging current | 100A |
Communication protocol | CANBUS/RS485 |
Working Temperature | -20℃-70℃ |
Parallel connection | Max 15pcs |
Working mode power consumption | <40mA |
Sleeping mode power consumption | 0uA |
Remaining capacity protection | 5% |
Over current protection | 110A |
APP | IOS/Android |
PC software | use RS485 adaptor |
Can the BMS manage series connection for these batteries?
Yes it can.
Wow. Sounds like a great deal then. $400x4 for a 15kWh pack…
