So at last my thread on my build…
Some background… My longing for solar is not a recent story… I almost bought a solar franchise back in 2012, but that didn’t happen as I got another job offer at the same time…
Then in 2016 my longing for cheap water and a green garden won the vote for the available funds and I drilled a borehole and installed pumps etc…
Then some time in 2021 I bought some 5kva multis… sold one of the three and planned to use the other 2…
Just as I started I got a new job in Swellendam and since the multi is not nrs compliant I sold them and replaced them with one multi II, also 5kva…
So moved to Swellendam and started to pick up the pieces of the projects I had to pack away… and also gave some projects away…
Obviously the first project to be unpacked in the solar…
I wanted to build some DIY batteries and got 2 JBD BMSes from TTT… Just as I was about to request the invoice for the 34 cells another friend pointed me towards an add for two basically new BSL 6.4s, which I got at an absolute steal… Same price of building DIY… less than 'n year old and used extremely lightly…
So I ran to Melkbos and picked them up. BMSes both shows 100% health, and I reckon only 30 - 40% max was used on cycling…
So where is my system at now:
I am renting in Swellendam at the moment so decided to not fix everything to the wall…
I thus built a stainless frame with wood boards on and fixed everything to that…
The 5kva Multi II, the 250/100 mppt, cerbo, DB, two fuse holders and the batteries will get a seperate stand.
I don’t have permission yet from the landlord to put solar on the roof, but we’ll sort that out in time. If I don’t get permission I’ll fit the panels on a frame on the empty erf next to me… So we’ll see what happens on the PV side in the next week or so.
For starters I’ve started to wire up the DC side of things. Ordered all my correct cables from victron and used some 50mm^2 cable which I have plenty off for the DC cables. Just need to put some red and black heat shrink on them. For now just used blue for + as there is no red or black heatshrink in sellendam.
Got them crimped today at the workshop and connected them up.
The plan with the DC buss is to use the two fuse holders, one as - and the other as +… Will fit 'n nice big buss bar on their top and then fuse the batt, inv, and mppt all coming in from the bottom. For now just linked the inverter straight through on 160A fuses.
So yeah that’s where I’m standing… The batt comms with the cerbo seems ok… although it’s not picking up correctly… It sees them as LG batteries. But the comms are generally good between the batts and cerbo, it picks up the correct sum of capacities in terms of charging and discharging limits so generally happy about that.
Need to plug in the MK3 - usb cable over the weekend and set the inverter up from the laptop…
Then next week I need to get my RS485 to usb cable crimped as they don’t come with a RJ45 connector on the one side but just 4 bare wires… If that done then I can fit the Carlo Gavazzi ET112 into my main DB and also link that up to the Cerbo.
Plan is to split my main DB into essentials and non essentials, and then have the ET112 just after my prepaid box. That way I can feed back to my stove and geyser once my PV is up… Also got a CT clamp for the Multi, but believe it’s nicer to have a seperate EM connected to the cerbo for a better representation in VRM…
Anyway that’s about it for now, will update as I go along and as I might need some help setting up the victron gear…
