For those who want to monitor the temperature of their MPPT’s (Tested on CAN only) this is very nice.
You can switch the MPPT replay as well based on temp if needed.
Displays on the console (and VRM) as well.
I have been looking for something like this. I Installed it, added a custom modbus register and can pull the data into Home Assistant. Thanks for sharing.
I wonder why this is not a built-in feature of the GX? Will you need to re-install this once you upgrade the GX software?
A Multi-relay board that can also be configured as inputs is being worked on.
Do all the MPPT’s have temperature sensors in them? Looking at the 150/35 as an example. If not, is there a way to know which ones support this?
*Just looking towards the sensor support, not relay control.
