I am wondering if there is a sensible limit to query multiple registers to a Venus GX using Modbus. I did a sniffer trace and see my client queries every 150ms until all my registers are done and then waits for the next cycle.
Let’s say 10 registers in a 5s polling cycle. Can I query all 10 with a 150ms delay in between?
The question is: What is the recommended time between individual queries that is not going to kill the GX?
Ok, to delve into more details. When I do a Modbus/TCP query to my GX via LAN each register query is sent with a 150ms inter-query delay window. This means if I query 10 individual registers in a polling cycle I start with register #1 and after receiving a response I wait the remainder of 150ms then send the next one. Once all 10 are done I wait the remainder of 5s as my polling interval and then repeat the cycle.
EG. I query register 1 and the GX responds in 1ms meaning I wait 149ms then query register #2 etc.
The question is, how short a time between individual register queries is considered acceptable? If I make the inter-register query interval too small EG. <1ms then perhaps the GX might get overloaded, the CPU spike and all sorts of nasty things can occur. I need to know a sensible delay for the capabilities of the Venus CPU which is not the most powerful of the GX range.
Perhaps but my Client software is an Appliance interface and only does Modbus/TCP. I’ve narowed it down to a bug on the Client side which overlaps two registers and causes the GX to go into a spasm with illegal reads/writes to a particular register. Initially thinking it was too fast polling I now see that you can probably poll as fast as the device can respond - meaning as soon as you receive a reply to the previous query you can launch the next query.
Thanks for confirming. After some testing I saw the same on the Venus so CPU was not the problem, it was something else which I am still working on with the vendor.
