Thank you. Don’t diss a BMV.
Now that that “elephant” has been agreed upon …most BMS I’ve seen do not have a shunt. So there is that.
Wonder what the small 12v BMS would have done in this case … I don’t think I ever would have seen it, know about the problem BAR that my time to discharge would have dropped a lot, or I saw the cell/s dropping fast. Mmmm.
As per Phil. I would have been blissfully unaware of the problem until I realized my bank discharges in X hours vs expected Y hours, or I would have seen a cell volts dip by accident.
YES! Comparing BMV and BMS SOC’s pointed out a problem with a cell, or cells, near-instant.
I get this 100%:
BMS works on the current flow and voltage per CELL.
BMS works on the current flow and voltage of the BANK.
But also floating around in my mind is that:
Lithium banks do consist of lots of cells, I agree.
But so do lead-acid banks.
Each battery is made up of cells inside, making them 6v or 12v “holders”. So if a cell in a lead-acid battery dies, that battery is “dead”, and the SOC “in sy moer” too.
So in my view, apples for apples.
What irritates me the most, the coulombs counted by the BMV vs the coulombs counted by the BMS, is not in sync on a balanced bank … and I understand the reason being the BMS works the volts per cell, BMV on the volts of the bank, and cells act slightly different cause each one is measured.
So, in conclusion, Is this summary correct:
If you have a BMS with a shunt and one or more cells are out of whack, the BMS calculates the potential SOC of the bank, by counting the coulombs going into the BANK, seeing each cells volts, and if a cell, or cells, are out of whack, based on those cell/s volts, “knows” that the bank was not fully charged, therefore the difference in SOC?
Ps. Cause a BMV would have given a similar result on a lead-acid bank if one cell in a sealed battery has an issue. One would just never know the cell number, maybe the battery due to heat or balancer on it or whatnot. Apples for apples, ja?
THIS annoys me: The shunts not measuring the exact same all the time.
Bank volts are most of the time on par. SOC close IF cells are balanced …
