ITS Heat Pump in Home Assistant
Hi all
I recently got a 5.4 kW ITS heat pump installed, wifi control is via Tuya using the Smart Life app.
I could get it in to HA via the Tuya integration, but I can only switch it on or off and set the temperature, it will be nice if I can see its actual temperatures as well.
I read about a local tuya integration which exposes more sensors, but I’m not sure how much more info it gives you. I’m a total HA beginner and the local tuya installation steps I came across looks quite daunting.
Will it be worth trying to figure out how to use the local tuya integration, will it give me more info and control of the heat pump?
P.S. I already have a Astute on the circuit to monitor its actual power consumption.
Has this got the WiFi capability?
Product Manual domestic HP Wi-Fi 2023_V1.pdf (840.3 KB)
