AHA, I see where you are going and coming from, and you are spot on.
In all my cases the batteries were THE most expensive part of the purchases.
And Online Double Conversion UPS’e was never the answer.
I mentioned them in the context of solar inverters having the same protections built-in, even though I can use my Online APC 48v 2.4kw UPS on my lithium bank as long as the panels do the charging.
Not connected to Eskom in other words, as the chargers in them are stupidly small.
For clarification: Using the 50amp charger in a solar inverter vs a 50amp charger in a UPS, if both solutions have the same sized lead-acid bank that can last 5 hours (2 x Eskom failures), both the solar inverter and UPS will take the exact same time to recharge those banks. If you go lithiums on both, same time to recharge, although much faster.
Where the difference comes in, and only really daytime AND with good weather, is a hybrid grid-tied solar setup - one that CAN use the panels with Eskom being off - with lithiums. Then the batts are not used during daytime LS events, when most businesses operate … and one saves the rest of the year on Eskom cost to recoup the initial outlay.
Here’s the thing in my cases, each and every client rented office space, no option of adding solar panels ever.
Today, if a client has no chance of panels being added, I recommend Axpert solutions, 5kva ones, get more than one and split the loads, and If there are multiple LS events in their area, get lithiums, they last longer and charge faster.
As much as I bat for Victron, as a UPS, it is a VERY expensive 5kva UPS compared to Axperts - unless you want panels to go grid-tied.
Ps. If anyone repeats that I said a good thing about Axpert (spit) - NOTE that it is as a UPS’s only!
