I’m looking for some advice or alternatives if my thinking is flawed.
We have a motorised gate serving 25 properties, powered by a 2.5 kWh 24v LFP battery, connected to a MPPT and 600W PV which is the only charging source, no AC, the site is off-rid.
We want to install a LPR camera at the gate, plus a Ubiquity Litebeam dish to connect it to the network, both these devices can be powered by PoE.
Here’s where it gets interesting, the LPR camera requires 48v PoE and the Ubiquity Litebeam requires 24v PoE.
So my thinking is, I need a PoE switch which can power both 24v and 48v devices and it must be powered by 12 or 24v DC, then I can chuck its AC power brick and connect it directly to the battery?
Will this work, any alternative, more efficient ideas?
I bought this TP-Link switch recently. It has a DC barrel jack on the back, can take up to 53V, and of course it ships with a PSU that you plug into AC.
The tricky bit will be to make 48V from your 24V. Of course the easy way is to use a Victron 24/48 DC/DC converter. But there might be other similar boost converter solutions.
For 12v, you get the same. You also get PoE splitters, which splits out the power from the network cable to a barrel plug for cameras that doesn’t support PoE. These can do 12v or 5v and you even get ones that split it out as usb-a/b/c to power items that doesn’t support poe. Great to have lots of things running off the PoE switch.
And yes, I do have a mikrotik, but I wanted to be safe that I only get the power out I need.
This project was on the back burner for a while, things got a bit crazy.
Amazing the results you get if you punch the right words in to Google, I came across a PoE switch which is powered off 12v or 24v and even looks like it has a option for solar charging.
There is 48v and 24v PoE on 2 of its ports, which is exactly what I need, so I assume there is buck-boost conversion going on internally.
There are some others as well, all essentially doing the same, I’m still researching different options.
