Home Assistant / Template / Defining diagram to show
Hi all.
I created a odd 40%pictures showing a water tank level at 2.5% increments (happy to share).
I have created a template that then populate a sensor (council_1_level_image) with the correct picture name to display as local/
pictures are in config/www/
Then created a dashboard…
the variable is populated correctly, but not getting the picture displayed. pls see below, what am I missing.
G
resolved…
See: GitHub - georgelza/waterlevel: Python code to read 2 types of transducer water level sensors.
G
Looks good. Sorry if i missed it while going through the code, but you can even protect the pump from a dry run condition by cutting the power to it with for example a sonoff when the water reaches a certain minimum level.
No sweat…
I’ve had the auto shut down in for a while, but my previous level checking was based on the ultrasonic and they unreliable.
Also long time have electric valve in place thats controller by a relay board, triggered from a sonoff dual 12v thats tasmotized.
G
