Hi @georgelza
I had the same issue and added this flow to keep my connection alive…
Regards
Mark
[{“id”:“25a89599.dbc99a”,“type”:“mqtt in”,“z”:“ee98e462.9a0ed8”,“name”:“N/XXX/#”,“topic”:“N/XXX/#”,“qos”:“2”,“datatype”:“auto”,“broker”:“43d7acd6.ec9074”,“nl”:false,“rap”:false,“inputs”:0,“x”:130,“y”:40,“wires”:[[“8551369d.3cf4a8”]]},{“id”:“8551369d.3cf4a8”,“type”:“function”,“z”:“ee98e462.9a0ed8”,“name”:“NodeName from MQTT sub-topic”,“func”:“var topic = msg.topic\nvar arr = topic.split(”/");\nvar length = arr.length;\nmsg.nodegroup = arr[length-1];\n\n\nreturn msg;",“outputs”:1,“noerr”:0,“x”:460,“y”:40,“wires”:[[“9ce15878.9474e8”]]},{“id”:“9ce15878.9474e8”,“type”:“delay”,“z”:“ee98e462.9a0ed8”,“name”:"",“pauseType”:“rate”,“timeout”:“5”,“timeoutUnits”:“seconds”,“rate”:“1”,“nbRateUnits”:“10”,“rateUnits”:“second”,“randomFirst”:“1”,“randomLast”:“5”,“randomUnits”:“seconds”,“drop”:false,“outputs”:1,“x”:720,“y”:40,“wires”:[[]]},{“id”:“43d7acd6.ec9074”,“type”:“mqtt-broker”,“name”:“CerboGX”,“broker”:“192.168.2.201”,“port”:“1883”,“tls”:"",“clientid”:“MaritzPV”,“autoConnect”:true,“usetls”:false,“compatmode”:false,“protocolVersion”:“4”,“keepalive”:“5”,“cleansession”:true,“birthTopic”:"",“birthQos”:“0”,“birthPayload”:"",“birthMsg”:{},“closeTopic”:"",“closeQos”:“0”,“closePayload”:"",“closeMsg”:{},“willTopic”:"",“willQos”:“0”,“willPayload”:"",“willMsg”:{},“sessionExpiry”:""}]
