Hi all,
so officially I am on the point of giving up
I managed to integrate Venus into my home assistant and I am reading current data with no problems.
In my configuration.yaml I added:
Victron modbus:
host: 192.168.xxx.xxx
type: tcp
port: 502
However, as soon as I cut this out of configuration.yaml and insert it into a file on its own called modbus.yaml and include the line : modbus: !include modbus.yaml in the configuration.yaml, my config doesn’t pass when checked
configuration.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
The reason I am doing this is to try and configure option to switch the grid setpoint with a button that would be in home assistant (from 50w to 4000w with a single click)
Can anyone help me with what am I doing wrong or have any suggestion?
This is the error I am getting:
Invalid config for [modbus]: [modbus] is an invalid option for [modbus]. Check: modbus->modbus->0->modbus. (See /config/configuration.yaml, line 24).
EDIT:
Another interesting thing I saw when going through the log is the warning is sourced from HASS.IO
Log Details (ERROR)
Logger: homeassistant.components.hassio
Source: components/hassio/init.py:454
Integration: Hass.io (documentation, issues)
First occurred: 1:36:48 PM (1 occurrences)
Last logged: 1:36:48 PM
So it’s been a while since I’ve messed with yaml, but I would guess either drop the modbus: in front of the include instruction, or remove the modbus header in the included file.
Edit: I fixed up your post a bit to help get the config snippet across Tend to write quite a bit more markdown than most people, which is the language used by this particular forum software.
One more question, since I am trying to follow the instructions from the link I posted.
I created switches.yaml
and in configuration.yaml i added:
switches: !include switches.yaml
…and as expected it is not working (emoji smacking it self in the head)
Please help me with what am I doing wrong, or what is it that I need to do
Yaml is very sensitive , any mistake even spaces make you pay and if you dont know were to start it is quite a challenge. Personally I use Visual Studio Code to edit the files , at least it helps a bit to debug if need be.
