So now here’s a thing. Something happened here, between Saturday afternoon and early yesterday morning.
I went to bed all grumpy because of the heat pump. My mood was not improved when the fence energiser started beeping at about 1am. But two things
- a light marked “service” was glowing
- ADT didn’t call nor send anybody.
Then the energizer just died. Dead as a very dead thing. So this morning I put another battery in and it started working. But there was another warning light glowing.
So I call the guy who looks after my security and gate, and he surpassed his usual high standards and got here today. The energizer had been fitted new earlier this year. The old one, that I still had, wasn’t putting full woema on the fence. Wizord said it was the HT transformer and that costs as much as a new energizer, and the replacement was quicker. So we went that route.
Frans (security guy) is scratching his head. The energizer is saying it’s getting no mains. But we’ve measured right up to the socket and there’s 230V all the way. No fuses blown. So he says “lets hook the old one up”. And it works, with the drop in fence voltage, but no warnings.
So, what had happened is that at some point something had failed and the energizer started running off of the battery and eventually ran it down.
Then Frans tries to get out. Garage door won’t open (it had worked this morning when my wife went out to get the battery for the energiser). A quick bit of trouble shooting shows a blown fuse on the line that carries grid voltage into the transformer that steps the voltage down for the motor. In the event of a grid failure you will get a few operations off of the battery. Which is what happened.
But whilst we’re looking at this, I had turned off all the plug breakers on the DB and turned them back on again (Frans did not want to believe my kill-a-watt). As things come back on they beep. But there was one beep less than usual.
Hmmm… Frans goes, but my mind is still wandering on. So I press the panic button. Usually you hear a relay click. Then ADT will call. Neither of these things happens. Then I notice the control panel for the alarm is dead.
This time I have an idea where to look, given what has happened up to now. Yep. There’s a little PSU box which powers the alarm system screwed to the wall. Has a screw in fuse holder. Fuse is popped. So, again, this is on the input side of things, the grid side.
So now it’s looking like something happened but who knows what. We’ve had no storms. There was nothing turning off and restarting unless it was during Saturday night (last time the heat pump ran was Saturday lunch time).
I am waiting to see what else won’t work. And I’m surprised because these are backed up circuits and the PV system has SPDs between it and the grid, and between it and the backed up circuits.
But it looks like something happened between Saturday afternoon and Sunday morning that fried a lot of stuff.
Insurance sends a plumber out to check what I have. He tells me two things
- it’s electrical
- insurance will send out a sparky to investigate.
Kwikot thinks it’s the transformer. Like the gate motor, the mains comes in, and is stepped down for the motor and the PCB. But unlike the gate motor there is no fuse on that line. Frans had told me that that fuse is purely sacrificial - it’s to help protect against surges on the power line.
I don’t like somethings.
