Is it possible to add ‘Writable’ Scheduled Charge Schedules to the Modbus queries mapped to the attributes file? I’ve added the below and can read the data but I cannot change the schedule via Modbus.
I can’t say why that doesn’t work. Just from a quick glance, it should. You have a W at the end (writable), and they are integers (string writes are not currently supported). It should work.
Have you tried writing single registers, or only as a range? There is an issue in dbus-modbustcp that if you write a range that spans across a service boundary, it doesn’t work. Well, reading is also broken, but the tail end just returns zeros so it is less noticeable.
@plonkster I tried a single write using ModBus Poll and that also doesn’t work. I suspect the ‘Set’ method might not be supported so I changed to MQTT, using SetValue, which seems to work fine. To be honest, I don’t know why other registers work but my own doesn’t unless it’s hardcoded somewhere.
OK… but still, I found that sometimes tools are one off on the registers, for some reason. It’s a long shot, I admit, but sometimes it pays to play around a bit. Fetch something you know absolutely SHOULD work (say, slave 100, address 800, the first character of the serial number). Then work from there.
