Item: 16x Svolt 184ah Cells & accessories (I have 2 sets of these)
Age: New
Price: R27 000 per set
Payment Method Accepted: EFT is preferable
Warranty: No
Packaging: Some of the original packaging
Condition: Brand new, unused
Reason: Plans have changed
Shipping: Yes, your cost & risk
Collection: With pleasure
Link: SVOLT 184Ah 3.2V LiFePO4 Blade Battery Cell – ALTERGRID lifepo4 cell
So I was planning on building 2x DIY batteries each consisting of 16 of these Svolt 184ah blade cells although plans have changed so they’re going up for sale.
I have pretty much all other accessories required to build the battery, below is a list of what I will include with each set:
16x Svolt 184ah Blade Cells (9.4 kWh)
1x JK 150A BMS (JK-B1A24S15P) with balancing cables & temp probes
1x JK BMS button
1x set of 5m silicone red & black cable & ring lugs to extend the balancing cables if needed
1x Set of busbars & clips to connect all cells in series
1x Set of nuts & washers to secure the busbars
1x Victron M8 dual terminal set (red & black)
6x Wago PCT223 Connectors to easily extend the BMS balancing cables (if needed)
As mentioned, I have 2 of these sets and each set would build a 51.2v battery with a total of 9.4 kWh.
If you were to take both you’d then be sitting with 18.8kWh of batteries for under R55k, some of the parts are not available locally and I have to import them (like the clips & busbars)
These are LiFePO4 cells, they are brand new first life cells and are 1C rated. At this price it works out to R2872.34 per kWh
