Real EVE LF105 3.2v Lithium Iron Phosphate (LiFePO4) battery cells.
ZAR 1495
This is not a HOME USE battery, but a raw lithium iron phosphate cell used to custom-build Lithium batteries.
NO BMS included.
Used for Solar energy storage, solar power system, UPS supply, Engine starting battery, Electric bicycle/motorcycle/scooter, Golf trolley/carts, RV, EV, Caravans, etc.
The cells are supplied with M6 studs laser welded onto the cells.
No other accessories are supplied. Just the cells.
The battery is suitable for DIY or battery builders with experience.
Model: LF105
Nominal Capacity: 105Ah
Nominal Voltage: 3.2v
Weight : 1.98kg ± 60g
Dimensions : 130.3 x 36.7 x 200.5mm
Standard Charge/Discharge Current : 0.5C/0.5C
Maximum Continuous Charge/Discharge Current : 1C/1C
Pulse Charge/Discharge Current(30s) : 1C/3C
Charging Cut-Off Voltage: 3.65v
Discharge Cut-Off Voltage: 2.5V
Charging Working Temperature: 0℃~65℃
Discharging Working Temperature: -20℃~60℃
Initial Internal Resistance : 0.32mΩ ± 0.05mΩ
Tests conducted on cells:
These 3.2V 105Ah Lithium Ion battery cells have passed all of the safety tests (overcharge, overdischarge, over temperature, short circuit, drop, crush, needle puncture).
That means even under these severe conditions these battery cells do not catch fire, explode or leak.
