Looking at our historic diesel spend that checks out.
Normally it was between R5-R7k pm, now we are averaging R30k+ pm (Jan was a new record at R55k but that includes local transmission issues due to our rainy season)
Also, I have to stress that the first three months of 2023 is 7 times worse than ALL of 2015. If we extrapolate to year end, times 4. That’s 28 times worse than 2015. But of course, I wasn’t being very scientific about that, so let’s vague-ify it and say 20 to 30 times
Funny dat, how life works. People do projections but that is almost always a linear function. Almost never a log function. If however, we just look at that graph, it almost surely is an exponentially worse situation. Generalised of course
Point being, like I mentioned earlier, it fails gradually at first, then suddenly
Sorry, should have said that is our usage at the company I work at (100kVA connection that is about 80% utilized in the daytime and about 15% in night time)
Personally at home I am in the sub 600kWh usage club
You had me thinking there for a second. Of course I expect that the usual relationship will apply: The rate of degradation is proportional to the current state of “degradedness” or neglect, which means you end up with a mathematical approximation that will have the letter e in it, and an exponent on top. Typically that formula (when integrated over time) yields something of the form X = xe^kt, where small x is where you started when t=0, and large X is where you end up.
But since e^x is the inverse of the natural logarithm, you are spot on by saying “log”, just bent the other way.
Logs are awesome, by the way. There is a little power management project of mine that uses the log of the delta between the current value, and the target, to essentially measure how many orders the two are from each other, and to tweak the alpha value if it is far apart and make the low pass filter move faster
Seems 29 March the first 500MW tender starts … ±3 years they recon and CoCT can shave off ±4 LS levels.
Discussed it the past weekend with FIL, when CoCT is “working” again in 2-3 years, what will the impact be when Cpt is operational, and people want to move down?
Two major problems:
Water … more people = more water required.
Power … more people = more power required.
… but forget traffic, there is little space to enlarge the main arteries.
So, Gov is in charge of water in SA right, same as with Eskom … wonder if CoCT can one day also take over its own water supply with no interference from National Gov … maybe also the police …
Ok ok ok … one thing at a time, or we will just declare the Republic of Cpt and be done with it …
Been watching how the buying power in and around Tygervalley has changed in the last ±5-8 years.
Makes me so happy seeing the rainbow nation in full force, families shopping, “the new taxpayers” spending monies, nice cars parked, spending on eating out … the same taxpayers that are referred to above, the middle class that earns the big taxes for the state.
Told the wife it is just awesome to see it all from “all white” a decade ago to “all South African” when you sit at like Tygerfalls having a beer, just listening to all the different languages spoken, the enjoyment of the people, the friendliness.
ANC, your days are number “bra” … numbered. The black middle class is becoming HUGE!
Yeah yeah, I know … a small teeny little microcosm yes … but there are thousands of these examples all over SA. Just takes a moment to sit back and watch, take it in, and see it happening.
