I still need to test mine more, after some searching though I found this;
This is mine;
template:
#Split power in and out of battery
- sensor:
- name: "Battery input power"
unit_of_measurement: "W"
state: >
{% if states('sensor.battery_power')|float >= 0 %}
{{ states('sensor.battery_power') }}
{% else %}
0
{% endif %}
- name: "Battery output power"
state: >
{% if states('sensor.battery_power')|float < 0 %}
{{ -1 * states('sensor.battery_power')|float }}
{% else %}
0
{% endif %}
Then I do the normal utility meter
Edit: Seems to be working well.
