Can anyone point me to the correct sensors I need to use for Grid (Consumption/Return) and Battery (Charged/Discharged).
I have HA/Node Red and use the Victron GX integration (which may be missing some sensors …?)
I can’t seem to find the correct ones…
Did you manage to get it working?
The sensors might be there, but you will only be able to use them in the energy management config if they contain certain attributes (you could potentially override these if the integration does not add them)
Use the Dev Tools → States to look at the attributes of existing sensors
"state_class": "total_increasing",
"device_class": "energy",
"unit_of_measurement": "kWh",
Hi Mark I have some digital kWh meters. Wonder if they have a communication port. I’ll look when I go down to the workshop.
