I have edited and changed the utilis.py file as you explained and it works perfectly until I restart the cerbo, then the changes disappear and the original file returns with the values for lifepo4
Maybe I am not editing it correctly, I do it in the cerbo entering the terminal as root and editing the following file: /data/etc/dbus-serialbattery/utilis.py
and I use the nano command
That is the correct way. The only way it will revert is is the changes was not saved correctly or if you reinstalled the driver (it will be replaced with the default values).
So if you edit it again, save and then re-open the file to check it should be fine.
Ok. last night started one bank and try to connect to the bms with the new app. No luck. So I guess the new series of this bms is running a new chip set or something.
Quick question @Louisvdw is there a way in the drivers to run 3 and more bms and that the software/script can pickup every unit on it’s own and give you every unit info via the VRM portal and combine SOC and inform the the charging part what to do?
Thanks for all the help,
Have it working (2.80, 0.9)
learned: Victron VeDirect cable didn’t work but a FT232RL Ftdi Usb 3.3V 5.5V to Serial Adaptor Module does and you have to connect all the 4 wires (Vcc too)
On the AntBMS I used the LCD port from left to right: Vcc, Gnd, Tx, Rx
Still have that Too many levels of symbolic links error >
@40000000618f8d4d1611874c *** CCGX booted (0) ***
@40000000618f8d4e0164a6bc *** starting serial-starter ***
@40000000618f8d5100b1c1dc find: /service/dbus-serialbattery/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service/service: Too many levels of symbolic links
@40000000618f8d51075f4a7c serstart starting
Nice forum, got a lot of support with this, so happy now.
[edit] yes, have the BMS values in Homeassistant too via Modbus unit 1
That is great news @picard . Glad you got it sorted. Can you maybe post some photos of the FT unit with your wiring and what settings you used and a photo of you BMS . Whant to see what version you got.
Never had problems with the ANT BMS, it has a poor IPhone app but having the data now in Venus and Homeassistant that is less important. Battery is 450 Ah/24V 8S3P
Thanks for the photos. Looks like the old model ant bms. I got 3 of them that i bought last year and using them. How old is yours and where did you bought the FT232RL ? Will like to get them connected to my Cerbo GX or a Pi setup to see all the info. Just finished a big battery build over the weekend. 680ah. 100ah x 4 thats build in 16s2p per pack and n 150ah x2 that I build into 16s2p 280ah pack.
