My daughter’s system was finally updated yesterday. Installer added 14 x 445w panels and 2 UP5000 Pylontechs, and she had the inverter and batteries moved to her garage, to save space in their small spare office.
Very proud of the fact that she saved up for more than a year in order to do this upgrade, and would not accept my financial help to get it done earlier.
That looks like a very neat installation.
I would not put that much faith in the holding capacity of my walls, but I saw them being built and corners being cut, so quite possibly all other walls are better…
Not sure the exact size of those brackets but they look about 350 x 350 x 30 or thereabouts. Even the cheap crappy ones are rated at min. 100kg/pair load capacity, the better ones are rated at 300kg/pair. Shear strength of 3 wall bolts in each one will easily carry the weight of 2 x 45kg batteries unless she is living in a mud hut
True, and I have not yet had a change to go and view her new installation and to “stand back, mutter under my breath, shake the brackets a bit and declare, It will do” like a true Dad
