"The heat generated as a byproduct from the receiver is used to warm the water in the hot pit, while the electricity from the receiver runs a chiller to cool the water in the other.
" When energy must be dispensed from the plant’s storage, the temperature difference between the two pits’ water drives an organic Rankine cycle turbine.
“The turbine’s working fluid — ammonia — is evaporated by the hot water to turn the turbine and generate electricity.”
Interesting. At some point CSP plants stopped generating in the US, because it was not financially viable - and PV became so cheap. It looked like CSP was a dead horse.
It seems now that they are making a bit of a comeback with some plants not exporting power at all during sun hours, only from stored heat during peak hours. (ie. Crescent Dunes).
I am trying to think, why Winterton?
There is water, the Tugela check.
Colenso power station, now decommissioned, so under-utilized power line availability in the area check.
Otherwise, it seems a pretty random location choice as far as sunshine.
I am tipping towards calling BS on this one.
