Centurion D5 bridge/bypass IR
Hi guys
Can someone quickly tell me which 2 connectors to bridge to cause the IR to be bypassed.
I’m on a business trip and of course the sensor seems to have failed… need to WA Video instruct wife.
G
Google says remove the wire on Safety Close/Open…! Yellow in the pic below…
image|690x388
Depending on how it is configured, you may have to short it to ground. Ie install a loop from “Safe-common” to “close”. You will know quickly enough, if removing the wire doesn’t fix it, try shorting it to negative/ground instead.
It might be easier to just open up the IR beam itself, pull out the two signal wires (not the power wires) and either leaving them open (if configured that way) or twisting them together. Whichever way acts as a bypass and makes the motor think there is nothing in the beam.
