three newbie questions from a home cctv user:
- i have a 16 channel nvr, cat5 running to 8 ip cameras, i need to add two existing analog cameras to the mix. can i use passive video/power/audio baluns at the camera ends to feed power and data via cat5 to them and will i be able to view their video/audio as per the other 8 ip cameras?
- will the analog video be ok for indoor home use?
- can i run wifi video data from a wifi camera to my nvr via a router?
i ask for the baluns plus low cost analog 2mp camera is still cheaper than 2mp ip camera - especially for indoor home use.
regards
gabriel
EDIT - SOLVED
what did i learn or was confirmed?
- nvr will not accept analog cameras
- mentioned baluns will only work in cases where utp [cat5/6/7] are used with dvr and analogue cameras, i.e. baluns at both ends of utp cable
- in dvr/analogue cameras setup the dvr does computing of data whereas with nvr/ip cameras the cameras do data crunching hence analogue cameras cheaper than ip cameras
- wifi data feed can be pushed to nvr via router for storage, most cloud based storage costs subscription plus bandwidth, local data storage is cheap and easily accessible.
bottom line - knowledge is power and saves money
